Order Farmall Cub Parts Online
INTERNATIONAL CUB LO BOY 154
J.WINBIGLER
06-19-2005 16:52:26
I AM LOOKING FOR INFORMATION ON THE HYDROLIC SYSTEM ON MY 154 LOBOY. THE GUY I BOUGHT THE TRACTOR FROM BLEW THE HYDROLIC HOSE FOR THE MOWER DECK. I HAVE SINCE REPLACED THE HOSE AND A FITTING TO THE VALVES BUT CANNOT GET THE ANY FLUID TO THE CYLINDER. I HAVE GONE SO FAR AS TO TAKE OFF THE AN END CAP TO SEE IF ANY FLUID WOULD COME OUT.I HAVE ALSO PUT ROUGHLY 1.5 GALLONS OF FLUID INTO THE REAR END.ANY ADVISE GIVEN WOULD BE GREATLY APPRECIATED. THANKS
El Toro
06-20-2005 07:51:10
 Re: INTERNATIONAL CUB LO BOY 154 in reply to J.WINBIGLER, 06-19-2005 16:52:26
Why did you put 1.5 gallons of oil into the rear?
Your hydraulic reservoir on your Cub holds 4.25 pints of Hytran hydraulic oil. The fluid level
should be within an 1/2 inch of the filler opening. Hal
Ksfarmmer
06-20-2005 06:33:02
Never have worked on my hydraulics other than replacing a hose. Didn't have a problem. Try the following site which is dedicated to numbered lo-boys:
http://groups.yahoo.com/group/ihcubloboyseries/messages
