Clutch pedal replacement.
hfarmall
06-19-2005 19:10:46
Where is a good place to find a replacement ( M farmall )clutch pedal. The shaft is OK, but the pedal egged out. Thanks for any help.
hfarmall
06-20-2005 19:22:48
 Re: Clutch pedal replacement. in reply to hfarmall, 06-19-2005 19:10:46
Hi, Is the shaft connected to anything inside the transmission ? Thanks, Mike
scotty
06-20-2005 04:47:50
HFarmall, Any good machine shop can help you out, I just rebored my right brake pedal support on my 49 Super A and pressed a steel bushing into it to get rid of all the slop. The support was .025 big. Dont forget to redrill the bushing for the grease fitting!
scotty
RustyFarmall
06-20-2005 04:34:51
Take the pedal and the shaft to a good machine shop and have them make a bushing for the pedal.
Nebraska Cowman
06-19-2005 19:49:49
Sometimes I find good used ones but not always. You might be further ahead to have a bushing put in it.
