Farmall B Spark Problem
Leon Worm
06-20-2005 05:54:51
While cultivating with my farmall B it suddenly stops running after about an hour and a half. If I wait two to three hours, it willstart right up and run for another hour or so and quit again. It has no spark when it quits. It has a magneto ignition. Can someone tell me what the most likely problem? I think it is the coil or possibly the condensor. I have removed the kill switch wire and it still has no spark. Is there any test I can perform to narrow it down? I appreciate any input.
Fred {Mudd} Hudson
06-21-2005 02:14:11
 Re: Farmall B Spark Problem in reply to Leon Worm, 06-20-2005 05:54:51
Leon take Hal and jon's advice to the bank.I got the the whole ball of wax { point's ,condenser , rotor,cap,coil,plug's,and wires , for a grand total of $92.00 .Had a time with the timein marks on the rotor drive gear{thanks to these two { Hal and Jon }she is startin faster than the wife headin to a shoe sale !!!! Get the points gap on the button it makes a world of differance ,or at least it did on my B. Fred
MagMan
06-20-2005 11:04:15
Yep What Hal said, Let me know if you need parts or service. JON
El Toro
06-20-2005 06:05:39
I would check your point gap .013" and make sure they're opening and closing. If this is ok I would replace the condenser to see if that fixes the problem. Make sure the points aren't dirty or pitted.
If it doesn't, it's probably a weak coil. Hal
