Super A - Low Power Problem
Stan2270
06-20-2005 15:39:42
Just got my new Super A running again (replaced radiator and starter switch) and now it seems down on power. Died in the field but restarted - seems like its not getting enough gas. I am going to re-build the carb tomorrow. Also noticed mild back firing after shutting down - could the valves also need adjusting? Lastly, is there an easy way to check if the governor is operating correctly? Thanks in advance for the anticipated advice.
El Toro
06-21-2005 05:19:14
 Re: Super A - Low Power Problem in reply to Stan2270, 06-20-2005 15:39:42
I would check the valve clearance. Should be set at .014" hot. Check for any blockage in the gas tank such as rust or dirt. If that carburetor has a main jet adjusting screw, it should be opened a turn ccw. Hal
BobOH
06-20-2005 18:39:56
Stan- I would take a look at the points and condensor.
Stan2270
06-20-2005 20:28:41
 Re: Super A - Low Power Problem in reply to BobOH, 06-20-2005 18:39:56
OK - thanks for the advice...
