Grease for Water Pump--1944 Farmall M
Charles Park
06-21-2005 07:05:54
What type of grease should I use to repack the bearnings in the water pump?
Andy Martin
06-21-2005 10:31:25
 Re: Grease for Water Pump--1944 Farmall M in reply to Charles Park, 06-21-2005 07:05:54
When you say "repack" it makes me think you haven't seen the zerks on the carburetor side. They may have brass caps screwed on. Use the same grease you grease the tractor with.
Charles Park
06-21-2005 11:33:38
 Re: Grease for Water Pump--1944 Farmall M in reply to Andy Martin, 06-21-2005 10:31:25
Thanks. I have taken the pump apart. Just making sure it is clean after the sand blast job.
Wanting to grease the bearings before reassembly.
Theman
06-21-2005 08:09:55
A good grade of chassis grease. Use sparingly - there isn't any way out of the pump except through the packing or a seal. The manual has specifics. I give my H two grease gun strokes per year.
