IH Side Delivery Tire Size
Jim Calhoun
06-21-2005 10:06:35
I need to know the correct tire size for an IH side delivery rake. It is approximately 30 years old and is driven by a chain from the wheels to the gearbox.
Illinois Boy
06-21-2005 12:10:21
 Re: IH Side Delivery Tire Size in reply to Jim Calhoun, 06-21-2005 10:06:35
Jim,
old is right - you don't need $50.00 / 6 ply implement tires to put on a rake!!
I've got old car tires (5.90x15 4 plys) on my rake and it doesn't know the difference. Think I paid about 7 bucks each for 'em. The 5.90 's are smaller in size and may well solve your height problem.
old
06-21-2005 11:45:29
If its like my rake which is also an IH, it has 15 inch tires on it. I use used car tire on it and it work good that way and cost is very low
Jim Calhoun
06-21-2005 12:00:01
 Re: IH Side Delivery Tire Size in reply to old, 06-21-2005 11:45:29
Yes it has 15" tires, but I need to know the height. I am at the end of adjustment ani the rake is still too high, so I thought as long as I had to change the tires I might as well put the correct ones on, or match the correct height with used car tires.
Andy Martin
06-21-2005 13:02:22
 Re: IH Side Delivery Tire Size in reply to Jim Calhoun, 06-21-2005 12:00:01
You can run them half flat, too, to help with the height.
old
06-21-2005 12:18:07
I think the ones I have on are 225-R15s
