MD miss fire
pvne
06-21-2005 20:43:09
I have a MD that misses on cylinders 1&2 on both gas and diesel.Tractor has been inactive for some time.Good compression on both cyls,valve clearance correct,spark/plugs good,injectors bled,filters changed,fresh fuel in tank.Excessive smoke when on diesel.Are the injectors leaking,would this cause it to miss on gas also?Any help/suggestions would be appreciated.
Thanks
Phil
Janicholson
06-22-2005 09:20:24
 Re: MD miss fire in reply to pvne, 06-21-2005 20:43:09
If the intake manifold butterflys are not connected on 1/2 of the intake system, there will be no gasoline going to those cyl on warmup. These units do not start on diesel unless very warm/hot, then they won't crank due to compression loading.
I'd look to the intake pluming. I seem to remember a coupling (or some linkage that might cause this symptom.
Good luck, they are great units.
Jim Nicholson
pvne
06-22-2005 20:02:39
 Re: MD miss fire in reply to Janicholson, 06-22-2005 09:20:24
Could the butterflys cause it to miss on diesel also?
Andy Martin
06-22-2005 06:14:42
Diesel fuel can make it miss on the gas cycle.
Usage may correct the problem. Have you had it good and hot under load with injector cleaner.
El Toro
06-22-2005 03:48:43
Are you sure you're getting fuel to those cylinders? Hal
