Better front rims for narrow front 'C' ?
IHC Red
06-22-2005 13:51:36
I'm about due for new front tires... the originals are pretty much shot.
The original rims are a little wobbly and don't seem to be that rigid. Are there any alternate rims which are a little stronger and aren't too much wider that fit nicely on a narrow front 'C' ?
Maybe 15" rims from a 141 combine or an 'H' would work ?
Has anyone tried this ?
woodsman03855
06-22-2005 22:11:34
 Re: Better front rims for narrow front 'C' ? in reply to IHC Red, 06-22-2005 13:51:36
You always can new aftermarket rims, though cost is about $95 each...
Andy Martin
06-22-2005 14:50:34
the 15-inch rims on an H are 16-inch.
A lot of the old rims have lost some material to rust so new rims or better used ones may help. I have experienced the same problem. My problem is in bent rims from hitting small ditches, etc.
RickB
06-22-2005 14:31:51
You really need to find a better rim. After all, the originals only lasted 50 years.
