H Gov. to carb linkage
Kelly MT
06-22-2005 22:31:44
How do you connect the governor rod to the carb when installing the carb to the manifold on a IH model H? The enging runs wide open. Thanks for any help. PK
brainerd dave
06-22-2005 23:39:23
 Re: H Gov. to carb linkage in reply to Kelly MT, 06-22-2005 22:31:44
Installed a new carb on my H this morning. Make sure the tab on the governor throttle shaft fits into the slot on the carb. It helps if you have three hands.
haymeadow52
06-22-2005 22:59:10
just experienced this problem myself. The tab on the end of the rod must fit in the notch on the carb, otherwise the governor has no control and the engine will run wide open.
