IH 1256 - No steering and no brakes - help!
HolsteinHeifer
06-24-2005 06:05:16
Hi to all -
We lost our steering and brakes after splitting the tractor a half a dozen times within the year. First lost high and reverse and replaced the gears. Next we broke the speed range shaft when putting it back in. And now we lost the steering and brakes. Split the tractor again and pulled the speed transmission out to pull out and look at the TA pump (which we never got that far-also manual- IH original- says so) and noticed the clutch housing cover (with all those little bolts to take off) inside the gasket was ripped. So we figured that was the problem. NOT! We do have the whole TA gasket kit $90.00. I am new to this forum and have read alot (Great and knowledgable forum) but I do not understand where the MCV is on this particlular model. I'm thinking this may be the problem. By the way when we put the tractor back together we had the steering until we put the clutch in then we loose it. The filters are good. Actually we would loose the steering and brakes occassionally which started a few years ago in the colder weather. Now we lost it completely. And let me tell you if we have to split it one more time I think I'm going to loose it completely, just joking. Now I'm just guessing on the MCV as to what I read on other model tractors. So any and all suggestions welcome. You know it always seems to happen at the perfect time, just started haying in the U.P. Michigan.
Tina-
HolsteinHeifer
06-30-2005 06:00:02
 Re: IH 1256 - No steering and no brakes - help! in reply to HolsteinHeifer, 06-24-2005 06:05:16
Hi you all -
First of all I would like to thank all that replied and am sorry for not checking in sooner. Been busy haying and monkeying with the tractor. I did find where the MCV is, the illistration is in a different section of the International service manual. Had also replaced all o-rings, gaskets, etc. Also everything was still intact including springs. I guess because we are not professional mechanics our terminology doesn"t coincide with others. Sorry about that. We have always pretty much work on our own equipment because of cost and there are not a whole lot of great mechanics out where we live. Some mechanics we have used literally cost us more money. The point is we have been having troubles with the brakes and power steering for quit a few years mostly in real cold temperatures. What is happening now is we start up the tractor and we have brakes and steering. It all goes out when we push the clutch in - bango - no brakes or steering. When we push the clutch in we are losing pressure and when the clutch comes back up it seems like it is not building the pressure back. We then prime and start up the tractor again only to get the same results. Our next guess is the pump has gone bad. Will be checking that next between hay bales.
And to answer you (tractor vet) everything is fine concerning spines, PTO runs great, pressure plate,flywheel, etc. And no out of the ordinary noises. Sounds like it had always ran.
Any other suggestions would be appreciated and thanks again guys. Will keep you posted.
Tina-
the tractor vet
06-24-2005 20:35:29
The MCV is on the side of the speed trans clutch housing And has all them 1/2 inches headed boltsand a couple lines and some linkage . Now this is not something that a novice should get into as there are springs, valves, o.rings , and gskts that have to match what came out . And since you have had this tractor apart somany times loard knowes what all you have done . Have you ever looked at the splines on the inputs for both the transmission and PTO and the end of the pressure plate and loard knows how you slide it back together you could have damaged the pressure plate or clutch disk . When done correctly they just slide together and if you have to pull them together then you are doing something wrong. If the steering worked before you screwed with it then you done shot yourself in the foot as something is messed up and setting here i have know idea just what it is . Take some pictures of it all apart and all the pices and parts and maybe i can help.
w gatewood
06-24-2005 11:09:25
you have a mcv valve problem
Alvin NE WI
06-24-2005 18:44:34
 Re: IH 1256 - No steering and no brakes - help! in reply to w gatewood, 06-24-2005 11:09:25
whats that??
