Farmall 560 $$
mattlanisng
06-24-2005 16:25:54
Well tomorrow there is a 560 gas nf with straight hitch, that does not run on an auction. The tractor is a repo and it has been in the shed for years, the guy that owned it had some problems and parted it. The tractor has comp for all cylinders scratched on the hood, two are low. The tin work is great, tires ok. has fenders and 3800 hours. what would it be worth???
thanks matt
CNKS
06-24-2005 18:59:50
 Re: Farmall 560 $$ in reply to mattlanisng, 06-24-2005 16:25:54
Also depends on what else is wrong with it. As to the engine, a complete overhaul-pistons, sleeves, head work, reground crank, perhaps a reground cam, will be in excess of $1500, just for parts. I have a 460U that I bought in running condition, decided to completely overhaul the engine, low compression on two cylinders, needed cam, crank, and head work -- $1800+.
Nebraska Cowman
06-24-2005 16:44:14
$1000 would stop me
binderpower856
06-24-2005 20:36:30
 Re: Farmall 560 $$ in reply to Nebraska Cowman, 06-24-2005 16:44:14
I'm with you cowman... $1000 would seem outrageous, especially where it doesn't even have a fast hitch that could be sold off should the tractor prove to be garbage...
