Order Farmall Cub Parts Online
Cub aligning clutch
GNB
06-25-2005 15:22:26
I have never done this but I am putting my cub engine back in and was wanting opinions on getting the clutch plate aligned back. My Idea was to snug the pressure plate against the clutch where clutch plate would still move. slide engine into place over shaft and tightened pressure plate up through the inspection hole? It appeared to be enough room through the hole. Is it? Thanks for your input.
Gnb
old
06-25-2005 18:26:38
 Re: Cub aligning clutch in reply to GNB, 06-25-2005 15:22:26
I do it the easy way, I have a clutch aliment tool costs around $15 which is cheap and it works on almost any clutch. Any good parts store will have them
gene (Missouri)
06-25-2005 17:58:49
GNB:
Easily done as you suggested. There is enough room to reach the pressure plate bolts through the inspection plate hole.
Gene
Magman
06-25-2005 17:27:56
I also pick up junkers and cut the shafts off so I have alignment tools. I would imagine that a cub is smaller than and H cause I think I have an extra H shaft. JON
El Toro
06-25-2005 15:46:54
I used an old splined shaft from a junked car transmission. I've used sockets that will just fit inside the clutch disc to align the splined area with the pilot bearing. I also put a light coating of lubi-plate on the splined shaft so the
clutch disc will slide on easily when installing the engine. Hal
