706 Shifting
TGIN
06-25-2005 16:30:51
I`m replacing the wore out parts of my range shifter . Theres a pin that runs though the parking pawl and the rod that runs from the top to the bottom of the sterring tower . Will that pin drive out or is it somthing different , it dont want to move and I dont want to tear somthing up . The parts man said it`s not just a roll pin but to drill it out and replace it with one .
the tractor vet
06-25-2005 17:19:07
 Re: 706 Shifting in reply to TGIN, 06-25-2005 16:30:51
It was and OEM tappered grove pin and yes you can drill it out and replace with a roll pin but they are not as strong if i have to replace one of them i use a machine bolt and counter sink the side that is closest to the wireing harness so it does not rub the wires or anything else .
TGIN
06-25-2005 18:06:58
 Re: 706 Shifting in reply to the tractor vet, 06-25-2005 17:19:07
Which side will it drive out from ??
