350 utility power steering(long post)
Darren
06-26-2005 06:09:11
My dad has been looking for a good tractor to do some work with on his property. We ran across a IHC 350 utility. The tractor was in really good shape and the three point and everything else worked well. The power steering was not working though. The shop mechanic checked the oil level on the gear box under the steering colum and tried to put some oil in it but it ran out the bottom of the gear box. The steering would catch and then let go. The power steering unit is in the colum of this model. Is this a hard or expensive problem to fix? They want $2500 for it, should we make them a AS IS offer or walk away? Any help would be appreciated. Thanks
PAULIH300
06-26-2005 08:31:52
 Re: 350 utility power steering(long post) in reply to Darren, 06-26-2005 06:09:11
The power assist is thru the tractors hydraulic system.That fluid that was added is for the gear box part of the box...not the assist side.You probably have a welsh plug pushed out the bottom of the box itself.If the power assist doesnt work,either the valving in the pressure regulator block is messed up or the hydraulic assist unit that bolts into the box is worn out.
