350 Hi-Clearance W/TA
Randy-IA
06-26-2005 06:29:17
Hi , Does anyone know how many of these were built and what they would sell for today in a totally restored condition with less than 1000 original hrs ? That sounds like an oxymoron , less than 1000 hrs and totally restored . Anyway , It's got what I condsider as everything , 3-point , power steering , fuel gauge in the filler , front corner weights , front wheel weights , rear wheel weights , shock absorber on the pto engagement , new tires ( 4 ) , new steering wheel , new seat and it starts and runs great . It probably has more but I'm not a expert . I'm not looking to buy it or sell it , a freind just got it at an auction and I told him I'd find out what I could about it and what one might go for in other parts of the country . Thanks ...Randy
Harold H
06-26-2005 16:18:18
 Re: 350 Hi-Clearance W/TA in reply to Randy-IA, 06-26-2005 06:29:17
Is it a Farmall Hi Clear which has drop housings on the rear axles and flat platform with high seat or is it a International Hi Clear utility which has seat straddling the transmission and adjustable rear axles where you slide the wheels in and out?
Harold H
Randy-IA
06-26-2005 10:02:03
 Addendum-Re: 350 Hi-Clearance W/TA in reply to Randy-IA, 06-26-2005 06:29:17
Hi , I was just looking on tractor data . com and iron search for this 350 I'm talking about and the one picture of a 350 on iron search doesn't look much like the 350 I'm talking about other than it's red . This one has the words High-clearance in chrome under the 350 on the lower front of the hood , it has a different type of seat with a backrest ( which I'm told is original )and a few other things seemed different . Could this one be a utility version ? He was in a bidding war with an oilman from Texas who wanted it BAD . He ended up paying over 15K for it , then the oil guy called him and offered him an extra couple grand . Seems as though this was one of only a couple of VERY limited edition tractors . I Dunno myself . It's a sweet little tractor though . ...Randy
CNKS
06-26-2005 14:10:19
 Re: Addendum-Re: 350 Hi-Clearance W/TA in reply to Randy-IA, 06-26-2005 10:02:03
If you straddle the transmisson when you sit on it, it is a utility. The high clearance utility was called a 350 Hi Utility. The row crop high clearance was called 350 High Clearance, sounds like what you have. There were only 151 of the row crop version made -- the chassis prefix is 350HC-- the Hi utility numbers are apparantly not available. Some of the high clearance models had a non-factory conversion to give them even more clearance. I have never seen one, only pictures.
GordoSD
06-26-2005 07:15:12
I'd say it would bring over 3500 here in East SD.
GordoSD
