H engine vibration
JBW
06-26-2005 07:15:50
My 43 H was overhauled with new valves, sleeves, pistons, rings, bearings, ground crank, resurfaced flywheel and new clutch. It runs much better, except it has a vibration (as it did before the rebuild) at around 1/3 throttle. It smoothes out at higher speeds, but at 1/3, it vibrates everything. Could the flywheel have somehow warped over the years and gotten out of balance ? Is this common ? I’m sure its coming from the engine as I’ve taken off the water pump belt and the vibration is still there when the clutch is pushed in. Thanks for any help.
JBW
06-27-2005 16:33:05
 Re: H engine vibration in reply to JBW, 06-26-2005 07:15:50
Thank you for your insights. Sounds like it's probably just the nature of the beast so I won't worry about it. Some day when I'm really bored I might try swapping the flywheel and see if it makes any difference.
Mark J. in Mi
06-27-2005 06:55:53
I have two 1944 Farmall H's. One vibrates as you described and the other one doesn't. Don't know why and it doesn't seem to hurt it.
Thanks,
Mark
THEkyroastnear
06-26-2005 14:21:17
my dads 45 H does it too it was more noticed after last overhaul dosent seem to hurt anything
jayw
06-26-2005 09:57:18
JBW
I have a 41 H and it does just about the same thing you mentioned, Dont know if this is normal but alot of the early ones do that. Jay
RustyFarmall
06-26-2005 07:20:17
My 1940 H does the same thing, at about the same RPMs. It is pretty much normal. Seems like maybe IH had a fix for it way back when, different motor mounts maybe?
