IH 2250 loader for Farmall 706 ??
farmboykj
06-27-2005 06:50:05
I am wanting to purchase an IH 2250 loader for my Farmall 706 and have a question about the mounting brackets. Are the brackets for a 706 specific to that model or will brackets from another model of tractor fit my 706? I would like to know this information in case I run across a loader.
farmboykj
06-28-2005 09:42:30
 Re: IH 2250 loader for Farmall 706 ?? in reply to farmboykj, 06-27-2005 06:50:05
Thanks for all the information gentlemen. Now the search begins.
K.B.-826
06-27-2005 16:03:02
Yes, they are specific. Made that mistake once. I have no idea what tractor our 2250 came off of, but we had to drill several 1" holes in each bracket to clear the heads of frame rail-to front bolster bolts, to get the brackets flush up against the frame rails of the 706. The next winter, 706 went in the shop for rear end work, and we had to modify the brackets further yet to mount the loader on the 826. Be careful, don't take anything anyone tells you as 100% accurate until the brackets are on your tractor.
CEB
06-27-2005 14:11:43
Actually, several other IH's have the same frame as your 706. The 460, 560, 706, 806, 1206, 756, 856, & 1256 all use the same brackets.
Note: The 656 has a slightly different frame and will not fit. 66 and 86 series IH's have a different frame also.
GP
06-27-2005 07:20:09
Mounting brackets are specific to the tractor. Brackets from an 806 should also work. Maybe a few others as well. Brackets from a utility definitely won"t work without modification.
