Farmall A - colling system
Tom R. S.
06-27-2005 10:10:25
I"m wondering if you can use antifreeze in a 1945 A. It has no water pump so I guess it has the thermosyphon system. Will this work with antifreeze or must it use just water?
Bob
06-27-2005 10:13:22
 Re: Farmall A - colling system in reply to Tom R. S., 06-27-2005 10:10:25
We've used one with a 50:50 anti-freeze/water mix FOREVER, pulled a small manure spreader at temps well below zero, and raked hay in 90+ degree summer heat with NO problems.
It's best to thoroughly mix the water/anti-freeze before putting it in the tractor, or use pre-mix.
El Toro
06-27-2005 15:01:45
 Re: Farmall A - colling system in reply to Bob, 06-27-2005 10:13:22
I agree with Bob. I used a 50/50 mix too in an A,
mix it well before installing. Change it every couple of years before you lose the rust inhibitor. Hal
