C hydraulic's
Ditz
06-28-2005 09:16:45
I broke a rocker arm on my touch control unit. Looks like my 1950 farmall "C" only had one arm on one side and two on the other side instead of two on both side. Anyone know the reason behind this? Also if I bolt a rocker arm shaft and arms onto my unit that has four arms will it function properly?
farmallhal
06-28-2005 19:15:25
 Re: C hydraulic's in reply to Ditz, 06-28-2005 09:16:45
On my Super C the 2nd lift on the left side is operated by the left touch control lever on the light bar. It's function is to move the leveling link on the fast hitch which raises or lowers the left side of the fast hitch. Works great for a fast hitch plow or in my case a fast hitch scrapper blade. Maybe it would have a different function on a C without a fast hitch though.
wana be farmer
06-28-2005 13:56:37
they come with two arms on the left side and one on the right. this is looking to the front of tractor.one arm on the left is controled from one control and the other control operates one on the left and right.
