plugs
zetor1
06-29-2005 05:39:14
what is the correct sparkin plugs for a M farmall, thanks fer ya help.
John M
06-29-2005 14:11:47
 Re: plugs in reply to zetor1, 06-29-2005 05:39:14
Only plug that will run in any of my Ms with fouling are Autolite 3116s.
captaink
06-29-2005 07:44:14
Champion D-16 or equivalent was the factory recommendation. The D-15Y was Champion’s recommendation for many years to replace the D-16. These are for normal use.
Many here on the board recommend a D-21 or equivalent for light use, but this is a “hotter” plug that originally recommended and may cause problems under continuous hard pulling. I ma by no way recommending Champions, I am just familiar with their recommendations. Choose the brand of plug you like and have it cross-referenced over if you don’t like Champion plugs.
