Farmall M breaks....disc....
Fred Pearce
06-29-2005 10:36:32
Need help with an International M, it has two braking discs per side..for the rear wheel brakes...
Having a problem finding a part number for the discs they are six inch diam., 26 spline brake discs....or a rebuilder that could reline the one's I have...any help would be welcomed, Thank you ...Fred..
JHB
06-29-2005 11:09:07
 Re: Farmall M breaks....disc.... in reply to Fred Pearce, 06-29-2005 10:36:32
Pretty easy to repair. Just get new discs from your IH dealer, take the glaze off the metal surface the discs turn on, remove the ramps and balls, polish the balls or replace them if they are badly pitted, use lithium grease (small amount)on the balls and ramps, clean the splined shaft and lightly lub it with lithium grease, put it back together, adjust the brake pedal travel and use the tractor. Good luck.
old
06-29-2005 11:08:09
Any good Case/IH dealer should have them and probably other dealers also. We picked up a set a few weeks ago for a 300U and the place wasn't even a Case/IH dealer. Costs around $50 per side
Fred Pearce
06-29-2005 11:24:10
 Re: Farmall M breaks....disc.... in reply to old, 06-29-2005 11:08:09
The I-H dealer didn"t have a number for the disc....that"s the problem...they had twelve spline...seven and a half ince ones...if you have a dealer that has them...sure would like to know...thanks Fred..
Haas
06-29-2005 13:01:40
 Re: Farmall M breaks....disc.... in reply to Fred Pearce, 06-29-2005 11:24:10
Your dealer did not want to look, or did not know where to look for the part number. The special Lambert Brakes are on the parts CD. The disk part number is 358743 R91. About 5 years ago, the disks were still available from Case/IH. However get out your pocket book if they still have them. As I recall, they were $80 each. I have a Farmall MD with those brakes. I took the disks to a local clutch/brake supply house. They relined the disks for me and as I recall, the price for all 4 disks was less than $100. If your splines are still good on the disks, that is what you need to do. Hope this helps.
Nat
06-29-2005 11:36:11
Then they're not factory disc brakes. They're Lambert aftermarket brakes, which you cannot get replacements for at this time as far as I know.
You will have to have them relined. You should be able to find a machine shop in your area that does clutches. They should be able to do your brakes as well. I recommend relining with clutch liner or kevlar for best braking results.
