plugs for super m LP
MMjohn
06-30-2005 03:43:00
what is the best plugs for super M LP ? Do i need to run it on vapor or liquid to have the most hp. thanks john
Randy in NE
06-30-2005 04:19:16
 Re: plugs for super m LP in reply to MMjohn, 06-30-2005 03:43:00
The propane will be a liquid while it is stored in the tank due to pressure/temperature. The propane will be vaporized as it passes through the carburetor and is mixed with the air stream. The vaporization temperature of propane is -40 degress F which is also -40 degrees C. So if the temperature is above -40 and the pressure is reduced to atmospheric pressure then propane will vaporize. No idea what is the best plugs to use. This could start another series of debates. :>)
Nebraska Cowman
06-30-2005 04:13:14
vapor is for starting in cold weather. Run on liquid for power.
