12 volt coil?
Nebraska Cowman
06-30-2005 07:17:18
third party image
this coil is marked "12R" Does that mean that it is used 12 with resitor or does it have an internal resistor?
Janicholson
06-30-2005 10:12:55
 Re: 12 volt coil? in reply to Nebraska Cowman, 06-30-2005 07:17:18
From the shape I'd say it is IH for sure (you probably know that). It is black and shows no red so I'd also say it is not off of a letter series, nor a early number series. Check with the parts department to see if there were resistors on later model tractors. Some equipment, Ford cars for instance, use a resistor wire that goes from the switch to the coil. And a bypass wire from the solenoid to give the coil full volts with the starter in the circuit. If the coil has the same Ohms of resistance as a six volt coil (or within an ohm of it) it is a 12 v with resistor required. If the resistance is almost twice the Ohms of a six volt, it is probably a "non-resistor" type. I gave no Ohm specs because ohm meters don"t always talk alike at low ohms unless they are too expensive.
Good luck, Jim Nicholson
