Cylindr #1 which valve is intake smd?
Kidd
07-01-2005 13:59:39
Tryong to put the distributor back in my smd, what valve is the intake and which one is exhaust? I,m looking for tdc on one and then set rotor at 1 right ?
riverbend
07-01-2005 16:36:43
 Re: Cylindr #1 which valve is intake smd? in reply to Kidd, 07-01-2005 13:59:39
You might try posting again, but type a little slower. It looks like you are asking how to install a distributor on a diesel Super M.
It does not matter which is the intake valve, at TDC (compression) they both will be closed.
Do you have a manual ?
Nebraska Cowman
07-01-2005 16:27:05
You want to time it so it fires at TDC when BOTH valves are shut. If you look at the manifold you can tell which valves are the intake. The intakes are #2,3, 6,7
KIdd
07-01-2005 18:31:06
 Re: Cylindr #1 which valve is intake smd? in reply to Nebraska Cowman, 07-01-2005 16:27:05
Thanks
