another super A question- distributor conversion
Phil W in Michi
07-02-2005 04:27:06
The guy I bought the tractor from said the distributor was converted to a ? '47 dodge distributor? He said this conversion was common. Is anybody familiar with what this could conversion would be? I would like to get a new cap and points but factory parts probably won't work.
Thanks for looking.
Phil
Phil W in Michigan
07-04-2005 08:29:34
 PROBLEM SOLVED in reply to Phil W in Michigan, 07-02-2005 04:27:06
It appears to be the standard stock delco coil. I just tuned her up with TSC parts and she runs a lot better.
I guess the guy I bought it from really didn't know about the conversion. It appears to be a stock Delco distributor.
BillWV
07-03-2005 17:35:40
 Re: another super A question- distributor conversi in reply to Phil W in Michigan, 07-02-2005 04:27:06
third party image
If it was converted from a magneto, it will have a vertical distributor like this one. (My A after refurbishing).
Bill
Phil W in Michigan
07-03-2005 17:44:04
 Re: another super A question- distributor conversi in reply to BillWV, 07-03-2005 17:35:40
Waw Bill, That is a nice looking tractor. Mine does have a verticle distributor set-up. What type of distributor is on your tractor?
Phil
BillWV
07-04-2005 09:30:47
 Re: another super A question- distributor conversi in reply to Phil W in Michigan, 07-03-2005 17:44:04
Phil,
Delco-Remy.
They tell me if it is vertical, it has been converted from a magneto system, which I know is correct on mine because my Granddad bought it new in '47, and he was the one that changed it over.
Good luck,
Bill
gene b
07-02-2005 05:14:41
47 dodge would have been 6cycl how do you make one work on a 4cycl?
Nebraska Cowman
07-02-2005 05:06:09
I see lots of Delco Remy conversions. Is that what you have?
Phil W in Michigan
07-02-2005 11:42:00
 Re: another super A question- distributor conversi in reply to Nebraska Cowman, 07-02-2005 05:06:09
I will check on the delco Remy conversion. What does that look like? How could you tell?
I'm not sure what it is. I think the guy said dodge...too bad he didn't put a six cylinder in the tractor. That would be a bad little cultivator! :)
