Order Farmall Cub Parts Online
Cub engine speed and voltage
harvey2fords
07-03-2005 07:57:15
Two quick questions - I don"t have time this morning to search the arcives but will ASAP:
My new "48 Cub will not change engine speed when I advance or retard the throttle lever! Seems to run well below 1000 rpm, guess around 450 (by ear). Any suggestions would be appreciated.
And: What is the majority feeling about converting the cub to 12 Volt?
Thanks,
Harvey
Bob
07-03-2005 15:32:33
 Re: Cub engine speed and voltage in reply to harvey2fords, 07-03-2005 07:57:15
Verify that the linkage from the governor to the carburetor is not sticking. If that is free, it may have a broken governor spring.
Bigdog
07-03-2005 11:39:06
Check your governor to carb linkage. There is no need to convert to 12 volts. Just maintain the 6 volt system and it will crank over like it should.
