help needed on a 706
Greg Buraglio
07-04-2005 08:44:18
Hi, would someone send me a diagram and the parts needed to change my 706 to a 12 volt system? The most reasonable price parts and numbers for the alt. ect. ect. Someone told me their is a alt. one wire for around $30.-40 and is simple to hook-up. True or not. Would someone send me info. on good salvage yards for Int. parts? Any help would be greatly appreciated, new at this! Thanks GMB
Aces
07-05-2005 05:12:24
 Re: help needed on a 706 in reply to Greg Buraglio, 07-04-2005 08:44:18
Greg Every thing from the late 450's were 12 volt at least the big stuff
Leland
07-05-2005 04:27:46
If it has 3 filler caps on battery it is a 6 volt if it has 6 filer caps it's a 12 I have driven several 706's and never saw any 6 volts .
the tractor vet
07-04-2005 20:54:41
All 706's are 12 volt neg. ground diesels have two 6 volts that are hooked together for 12 . And if the genarator is in good working order and the regulator is doing it's job then it will handel the 4 lites in a flat top fender and tow lites on the back but the lite switch won't it will only take five lites . Now on the later model 706's they came from the factory with a alt. I have had both and the gen. will do the job and i use to do a lot of nite work.
Greg Buraglio
07-04-2005 16:12:44
Hi, thanks for the help. The wiring is not the best on it. I"m going to rewire it, and at the same time change (with your help, I now know that it must have a generator) I"ll change it to an altenator. What"t the easiest and cheapest for parts that I would need? Have any ideas!!!! It"t a 706 gas. Thank for your time and help. GMB
billde
07-04-2005 16:49:26
 Re: help needed on a 706 in reply to Greg Buraglio, 07-04-2005 16:12:44
Greg, I would suggest staying with the generator, it will be cheaper and easier. Unless you plan on running a huge set of lights the generator will keep up with the modest electrical demands of a 706 gas or diesel. In some cases in changing to an alternator you would have to change polarity, which can be a real pain. Also, the wiring diagrams for this tractor would cover a generator, not an alternator.
Jimmy King
07-04-2005 10:15:26
706 should be 12volt two 6 volt batterys in series, makes a 12volt.
David A. Hodson
07-04-2005 10:04:53
I agree with Bill never seen or heard of 706 being 6 volt, if its a diesel it could have 2 6 volt (3EH batt. type) hooked together to make a 12 volt or if gas a single 12 volt battery. David
billde
07-04-2005 08:54:48
Are you sure it's not already 12 volt? Never seen anything but 12 volt on a 706. Is it gas or diesel?
