Help for Farmall C radiator
Eastsider
07-05-2005 18:40:49
After getting a radiator from a salvage yard for our C, we went to put it in and found that it was one for an A/B.....Since the whole tractor was apart, we never thought to match up the top outlet to the water intake! Well, now that I have found another C radiator I have a question. The one I am getting is for a pressurized system. The tractor will be original and non-
presurized. Are there any modifications that need to be made to have it fit/work properly? I know that it needs new mounting studs. Any special trick to installing new ones?
Mark
CNKS
07-05-2005 19:32:29
 Re: Help for Farmall C radiator in reply to Eastsider, 07-05-2005 18:40:49
I believe you have to leave it pressurized, as the pressurized and non-pressurized radiators have different filler openings and the caps do not interchange. You might check and make sure the one you have is not for a Super C -- it won't fit.
