2N overheats
Scott Lathrop
07-06-2005 06:21:33
My Ford 2N overheats, but not all the time. Sometimes when it is working hard, but yesterday when I was cutting the pasture, not much load on it but it was about 87 degrees outside. What do you think? The radiators full. Maybe a new water pump?
Andy Martin
07-06-2005 14:33:40
 Re: 2N overheats in reply to Scott Lathrop, 07-06-2005 06:21:33
Check the fan belt too.
I was baling with my M the other day and it kept getting too warm and would not cool down like it should when idling.
I run the belts loose to make the water pumps last, but this one had gotten too loose, a little tightening and it is running good as new.
Jeb2N
07-06-2005 09:29:03
You may want to post this on the Ford N-series board, but usually, it would be something like:
1) radiator over full. Only add enough fluid to just cover the top of the coils. The rest of the tank is basically a reservoir for expansion. Too much water = boil over every time.
2) Thermostat in backwards. If installed, the pointed end points towards the radiator and goes in the upper hose.
3) Trash in cooling fins. Take an air hose and blow the trash out from the engine side.
Hope this helps.
Jeb
El Toro
07-06-2005 08:46:19
If that tractor has a thermostat I would check it
to see if it is opening fully. I would remove the thermostat for use during the summer and see if the engine runs cooler. Reinstall in the fall.
Hal
captaink
07-06-2005 07:39:52
I’m not familiar with a Ford 2N but here are some basics. The radiator allows heat to be transferred from the water to the air. You need good air flow through the outside of the radiator, good water flow through the radiator and good water to radiator contact which can be impaired with “crud” that forms inside the radiator.
To help out, carefully (I don’t know if that is a pressure system or not) take the radiator cap off and run the engine and look to see if you have water flowing in the radiator after it warms up a bit. If so then chances are the water pump is working and the thermostat is opening. If you don’t have water flowing it could be either the water pump or the thermostat causing your problems.
If you have good water flow, then the radiator may be dirty either on the outside or on the inside. Back flushing might help, but if the radiator is dirty on the inside it will probably have to go to the radiator shop.
One other thing to check is the ignition timing. Late spark timing will cause an engine to run warm.
