steering drive shaft on upper bolster on M
Kevin Brooks
07-06-2005 14:18:13
Is there a way to pull the steering drive shaft out for seal replacement without removal of the entire upper and lower bolster assembly? Can I just disconnect the upper bolster from the lower bolster at the four cap screws to accomplish this?
Andy Martin
07-06-2005 14:25:40
 Re: steering drive shaft on upper bolster on M in reply to Kevin Brooks, 07-06-2005 14:18:13
Yes, you can drop the shaft out the bottom after removing the lower portion.
BUT, if you just need to replace a seal, fill the gearbox with gun grease and don't look back. It has been proven modern gun grease will grease steering gearboxes just fine.
Kevin Brooks
07-06-2005 15:00:20
 Re: steering drive shaft on upper bolster on M in reply to Andy Martin, 07-06-2005 14:25:40
Thanks, Andy!
