Looking for Bearing for IH mower deck
TwinCam
07-06-2005 17:15:02
I'm looking for the bearing for my IH belley mower. This is a bearing on one of the two pulleys that take the drive belt from a horizontal position to the vertical position up to the drive pulley in the rear. This bearing is pressed into the pulley and has a 1 3/8 OD and a 3/8 ID with a 1/2 long sholder at 3/4 inch diameter. If you've seen the pulley and bearing, you will know what I'm talking about. Can you sell me one or suggest a vendor? Please advise and thank you.
Mark
TwinCam
07-07-2005 05:35:53
 Re: Looking for Bearing for IH mower deck in reply to TwinCam, 07-06-2005 17:15:02
Thank you folks. There are no numbers left on the blown out one, maybe I can see one on the good one. My tractor is a 1950 Cub and the deck is prolly from the 70's. The nearest IH dealer is a good hour away. I think I will order a bearing from McMaster Carr over the internet and turn the shoulder for it on a separate piece of stock on the lathe. If that fails, I'm out $6.00 and 30 min. lathe time and I'm on the road to IH. Thanks again and may your tractors keep on roll'n!
Mark
El Toro
07-07-2005 10:35:17
 Re: Looking for Bearing for IH mower deck in reply to TwinCam, 07-07-2005 05:35:53
Hi Mark, What's the model number of the mower?
Hoober Equipment in PA and DE keep a good supply
of parts for the IH mowers. Hal
1-800-732-0017
El Toro
07-07-2005 03:55:59
Your local Case/IH dealer should have them or
look for a number on the old bearing and your local auto parts dealer may be able to cross-reference it. Hal
Don L C
07-06-2005 18:27:29
The drive pully is on the engine...but I think I know the ones (there are two)I would replace both of them....If your tractot is a Cub Cadet go where they are sold, like Tractor Supply....If it is IHC go to CASE-IH dealer....tak the old one with you....
