Farmall B Exhaust Manifold
Leon W
07-07-2005 08:24:19
On a Farmall B, can the lead pipe coming out of the exhaust manifold to the muffler be replaced, like an H or is the pipe an integral part of the manifold? It appears to be threaded in to the minifold but I can't tell for sure.
Thanks!
MACE
07-08-2005 04:33:06
 Re: Farmall B Exhaust Manifold in reply to Leon W, 07-07-2005 08:24:19
You may be surprised by what you can break loose from light tapping and a lot of patience. I usually go the other route (heavy banging with a hammer) and it most always gets me into more broken parts.
MACE
Dave BN
07-07-2005 16:51:18
Soaked mine with Liquid Wrench every night for a week. I tapped straight down on it with a ball peen hammer for a while. Then used a 24" pipe wrench with a 20" exrension on it. Almost spun the tractor around befor it broke loose. Was afraid I would break the manifold but the pipe came loose first. I figured I had to replace the pipe and if I broke the manifold I'd replace it too. Penetrateing oil, tapping with a hammer and patience is the secret. Dave.
El Toro
07-07-2005 15:05:53
Hi Leon, Be careful when trying to remove the pipe from the exhaust manifold that you don't break the manifold. That pipe has probably rusted
over the years. Use an acetylene/oxygen torch to heat the manifold around the old pipe. Put some anti-seize on the threads of the new pipe when you install it. Hal
Red Dave
07-07-2005 08:28:41
Yes, it is screwed in. Inch & 1/2 pipe thread, if I remember right.
