Hydraulic Steering and brakes
Aces
07-07-2005 10:52:04
An other question in the last few days about steering and brakes on the IH with hydraulic steering and brakes 706 through 86 series tractors. They should all have steering and brakes without the engine ruuning. If anyone has a tractor that does not have steering and brakes you should check it out and fix it. To test the steering just turn the steering wheel with out the engine running the front wheels should turn it will be harder but should steer, if not could be the sump check bad it is at the lower in side rear of the MCV valve and will have to remove the MCV to replace. As for the brakes the first test is without the engine running, push one brake peddle until it stops then push the other peddle if the first peddle moves farther that firs brake should work, do the same test on the other peddle if it move when you start to push the second peddle that brake should work as well. If that test works as stated then stop the tractor on a save light slop, shut the engine off and see if the brakes work. If these test don't work then most likly the self adjusting screws in side the brakes are not adjusting the brakes. They will need cleaning and the screws should be free to turn with no oil or lube and the stop clip must lit the screw turn free. If this is good them could have bad master cylinder.Should be able to slid rear wheels with out engine running.
I post this for safety reasons, do the tests now and then to see if they work, fixed may of these brakes never had one that would not slide the wheels.
Brian Klock
07-10-2005 04:13:32
 Re: Hydraulic Steering and brakes in reply to Aces, 07-07-2005 10:52:04
I have a Farmall 706 hydraulic brakes-just had brakes overhauled, put back on, they seem to be dragging slightly until brake drum heats up and the problem accelerates and brake housing gets so hot can't touch it. also adjusted brake with set screw we no positive results. suggestions please?
Hugh MacKay
07-08-2005 03:16:30
Aces: Quite agree with you on the brakes, however the steering is another matter. when my 1066 had less than 100 hours on it, broke a rocker arm. Called IH dealer and there was a recall on those, he had a complete rocker arm assembly in stock for my tractor. He wanted us to tow tractor not running to a source of electricity, and he would send a serviceman right out.
Since all my other tractor were busy and route was quite level, we attempted this tow job with Super A. We had a couple of 90 degree turns through gateways. Hardest pull the Super A had was pulling sideways on front end, thus forcing front wheels to steer. You could for the most part steer it on the straight away and slight curves. The tractor was dualed and had 6 front weights. You could follow it on the steering wheel as the Super A pulled sideways. No way you would ever steer it sharp. Big task was getting the front wheels straight after the turn. Remember this was 1975 and tractor had less than 100 hours on clock. My 656 was somewhat better on steering without engine running. I would however not want to get caught with either on a sharp curve in road and steep embankment and have engine fail.
