706 shifter oil litght
VOLfarmall
07-07-2005 11:26:34
Bought a 706 everything seems tight and works lik it should, but it is hard to get into reverse the other gears are fine.also the oil light comes on and blinks when you push the cluth in?? It has 1500 psi hydralic press when hot is this right? Never owned a 706 before,as I guess you have figered out by now Thanks for any help
the tractor vet
07-07-2005 15:00:16
 Re: 706 shifter oil litght in reply to VOLfarmall, 07-07-2005 11:26:34
well since i guess i am the local GURU on the 06 and up tractors , like said before the teltale lite comes on when the clutch pedal is pushed down to the stop or just before and lets you know that pressure has dropped off because the dump valve is open .If you are having a problem getting it into rev. then there is ware in the linkage and also propably a woren rev. shifter shaft or even a broken rev shifter fork. or top cover . Ya have to look at everything when tryen to figure out what is wrong most of the time the problem is that she was used to much when it was new. But it is all fixable i have rebuilt somany of them that i can do them after a twelve pack . The big thing with 06and up seires tractors and shifting problems start with impropper clutch adjustment trans brake adj. and dump valve setting , when everything is wright then they will shift with just two fingers.
Nat
07-07-2005 11:28:15
If you are talking about the red light next to the key switch, that's normal. It should come on when you push the clutch.
