Farmall 200 steering gear arm
HFDFF32
07-07-2005 19:03:36
I am looking for a steering gear arm for a Farmall 200. The tractor is a tricycle frontend and I am wanting to put a wide frontend on it. I have the frontend but the steering gear arm is missing. If anybody knows where I can get one it would be appreciated.
riverbend
07-08-2005 19:44:06
 Re: Farmall 200 steering gear arm in reply to HFDFF32, 07-07-2005 19:03:36
I made a longer steering arm for a wide front for my C. The old one was bent and it steered like a pig.
The new arm is shaped like a truncated isosceles triangle. The holes for the bolts in the bottom of the bolster were 3 3/4" C-C, 21/32" diameter. The holes for the tie rod ends were 17/32" on the top and 5/8" on the bottom, 1 11/16 C-C. The original arm was 11/16" thick on the tie rod end. The sets of holes were 8 1/4" apart (front to back) on the original. I made mine 9 1/2". I think that another 1/4"-1/2" would be better.
If the holes in the 200 bolster are the same, try a mock up and see how it works. I used a piece of 3/8" scrap aluminum plate as a prototype. It has cultivated an acre of tomatoes and has not bent yet.
Calif. Farmall
07-08-2005 02:36:25
I have one but you can't have it HaHa! Sorry it's late and I just got out of the Hospital, That was a real good time! Anyway try www.jptractorsalvage.com . If your a fabricator you could make one out of 5/8" plate if it uses automotive style tie rods, if it uses ball tie rods your stuck finding one. Onother place is Bates ,they specialize in IHC stuff.
