What does this part number go to?
Rickyp
07-07-2005 19:37:14
362 173 R91. Thanks, Ricky
Nat
07-08-2005 06:55:49
 Re: What does this part number go to? in reply to Rickyp, 07-07-2005 19:37:14
I've gotta ask, what is the point of asking about a part number like that? You've got a part number on a piece of paper. You don't know what it looks like, so it could be anything from an gasket for an F-20 to a seat assembly for a 5088.
If you've got a part in front of you with that part number on it, that's different. It would be nice if you mentioned that, though. It would be nice if you described the part to help people narrow down which parts book to look in.
Guy Fay
07-08-2005 10:44:38
 Re: What does this part number go to? in reply to Nat, 07-08-2005 06:55:49
There's actually IH parts books that list all the tractor parts from a particular date range, roughly, and then what tractors or engines they go to. 19-XPG was one like that. Or else a friendly dealer can look it up on line.
justin w
07-09-2005 06:02:41
 Re: What does this part number go to? in reply to Guy Fay, 07-08-2005 10:44:38
The XP series actually only lists parts that were listed in the actual parts books. Any part numbers that were only listed in service bullitens or merchandisers, were not included in the XP series.. There are actually some fairly large holes. I have just about all of the XP series books, and the XPG revision 1 and XPG Revision 2 will get you up into the early 560 series tractors.
TDK
07-07-2005 20:54:35
362173R92 is a carb for a W-400/450 & most likely a Farmall 400450 also.
