H4 MAGNETO
RICK IN VERMONT
07-08-2005 15:40:19
I have a 1940 "A" tractor. The Magneto has a lever with a screw on the side with a cable attached. The cable goes back to the steering column to a knob. When you pull it, it moves the lever a very tiny bit. What is it for? What's it do ?
MagMan
07-08-2005 17:50:11
 Re: H4 MAGNETO in reply to RICK IN VERMONT, 07-08-2005 15:40:19
Yep there right . If you ever decide to take it off and put a push pull on and off switch on I will trade you a push pull switch for it. JON
Red Dave
07-08-2005 16:21:28
It is the kill switch. When you pull the knob, the lever grounds out the magneto.
El Toro
07-08-2005 16:20:24
I think that's your shutoff cable. When you pull
that cable back it will ground out the magneto so the engine will shut down. Hal
