Need Help on 560 Hydraulic Valve
Too Far Gone
07-08-2005 15:43:30
Inside the control valve for the fast hitch are 3 small bevel gears,2 of which are pinned to the shaft running through the valve.These gears are no longer available OEM.I need the gears and the shaft,or just a whole valve with good gears.Does anybody know where to get them?or get the thing repaired?Thanks for any help.
old_bc
07-09-2005 07:18:30
 Re: Need Help on 560 Hydraulic Valve in reply to Too Far Gone, 07-08-2005 15:43:30
If you don"t find one locally email greg@eldridgesupply.com. He has one.
old_bc
gds47
07-09-2005 05:13:13
You can turn the gears half over.I have done it on my 560 and it works fine
the tractor vet
07-08-2005 16:32:53
All dependes on where your at , I would opt to getting a whole teladepth valve and for me it would be no problem as there are several salvage yards that i deal with and get good parts.
the tractor vet
07-08-2005 16:32:46
Too Far Gone
07-08-2005 18:46:49
 Re: Need Help on 560 Hydraulic Valve in reply to the tractor vet, 07-08-2005 16:32:46
I have salvage yards here,but they want to bend me over a barrel for old parts that may not be any better than mine,and they also want to exchange the whole valve body,but the rest of my valves work fine.Unless I can find the part reasonable I will probably hook the hitch cylinder to another remote.
Hugh MacKay
07-09-2005 02:25:06
 Re: Need Help on 560 Hydraulic Valve in reply to Too Far Gone, 07-08-2005 18:46:49
To Far Gone: Like you I'm rather surprised anyone could find a good tele-depth control valve in any scrap yard. The valve in my 560 packed up 35+ years ago. At that time IH did have parts, but the cost was prohibitive even then. I replaced my tele-depth control with a regular valve from a scrap yard. Came from a 300 that burned.
I had a new 656 at the time and was fast moving to 3 point for mounted equipment. I scraped the 560 fast hitch and installed a standard M type drawbar.
