International 1066
Haley
07-08-2005 16:54:27
My grandpa needs help on his International 1066. We need to know how to adjust the clutch and torque. Any advice anyone?
the tractor vet
07-08-2005 17:23:14
 Re: International 1066 in reply to Haley, 07-08-2005 16:54:27
Does it have Hdy. assist ????? if it does not then set the free travel to 1 inch from the bak of the clutch pedal to the ft. edge of the floor plate then go to the right side of the tractor and there is a rod going down from the clutch cross shaft to a lever comming out of the bottom of the speed trans mission , loosen the lock nut first then pull the hair pin and and remove the pin then push the clutch pedal down to the stop and see how the pin fits in the hole adjust the clevis to where that pin will slide in free let off the clutch pedal and add one and one half turns to the clevis replace the pin and hair pin and lock the lock nut down next go to the left side to the tractor and there is a 1/4 inch bolt that goes from the clutch pedal to the dump valve onm the MCV loosen it a couple turns and start the tractor make sure that the red lite is working as you need it to work to make this adjustment push the clutch pedal down to the stop and start turning the dump valve bolt in and do it slow as soon as the teltale lite comes on stop let the clutch pedal out then add one more turn and lock it down all done now if it has hdy assist then we need to back up and i'll tell ya later.
