No oil in the 706 gas
Zale
07-08-2005 18:12:15
Hi there, my tractor does not smoke, runs good, but every time I check the oil, which has been often lately, there does not seem to be oil in the crankcase. Where is it going or do I want to know. Thank you for opinions.
El Toro
07-09-2005 07:39:44
 Re: No oil in the 706 gas in reply to Zale, 07-08-2005 18:12:15
If that tractor has the little check level drain cocks for checking the oil level as some of the older tractor's have, your oil may may draining
from one of these. It's either leaking or burning
it. Hal
P Backus
07-09-2005 07:19:56
It has to be either leaking it or burning it. If it leaks, just trace it down. If it is burning it, just keep adding oil. As long as it runs well it won't hurt anything. You could also check the breather. If the engine is worn, it can blow oil out the breather when you are working it, but not so much at idle.
Or maybe you lost the drain plug..... LOL!
Paul
