Mccormick-Deering 04 questions.
Centaur Nut
07-10-2005 12:18:28
Hey, Guys! Is anybody familiar with the 04? I need to know where the starter button was mounted & what it looked like, and what other Mccormick-Deering grill might fit, and where I might find one. Any help is appreciated! Rick.
BIG JOHN
07-10-2005 16:46:11
 Re: Mccormick-Deering 04 questions. in reply to Centaur Nut, 07-10-2005 12:18:28
The push button starter button mounts just the same as a W4, just above the transmission deck to the left of the steering sector. The grill from a W4 will work just fine the only difference is that the orginal O4 grill would not have holes for the mounting of the headlights on the side of the grill as the W4 does. O4 headlights are mounted at the bottom of the front casting on totally different mountings.
GOOD LUCK
Centaur Nut
07-10-2005 19:43:39
 Re: Mccormick-Deering 04 questions. in reply to BIG JOHN, 07-10-2005 16:46:11
I've never seen a W-4. Is the button like the one on a Farmall M?
Jeff In Ontario
07-10-2005 14:49:40
Rick:
A grille from a W4 should fit fine...depending where you are you will usually find a wrecker with one of those...if near Ontario, email me for the number of a parts yard here.
Jeff
Centaur Nut
07-10-2005 19:46:17
 Re: Mccormick-Deering 04 questions. in reply to Jeff In Ontario, 07-10-2005 14:49:40
I appreciate the offer, but I'm dead center of Alabama! If I can't find one closer I might call on you though. Thanks! Rick.
