300 Utility PARTS??????
Rabbitchoker
07-11-2005 14:25:16
I need to replace the ball joints on the ends of the steering drag rods. Checked at the CaseIH dealer today and they can be ordered but would cost about $450 for the set four. Is there any aftermarket supplier for these?
This is a wonderfull little tractor!! Thanks in advance.
300Randy
07-12-2005 08:31:12
 Re: 300 Utility PARTS?????? in reply to Rabbitchoker, 07-11-2005 14:25:16
OEM tractor parts out of Bloomington Ill. had them at one time. Call them at 800-283-2122
rabbitchoker
07-12-2005 19:19:37
 Re: 300 Utility PARTS?????? in reply to 300Randy, 07-12-2005 08:31:12
Thanks for all the great ideas and help. I'm going to try a couple of things and see if i can get the parts I need.
Van in AR
07-11-2005 20:59:10
If you have a good auto parts store around like I do, Its a family owned Bumper to Bumper, I needed the steering rod ends for a 354 I have, IH wanted $72.00 for the one. The parts store has a spec book on Moog and BW joints, you will need the old joint measured for taper, (will be A,B,C or D probaly) Then need measurement of thread diameter and thread pitch and if Left or Right threads. They found the two I needed in about 10 minutes and the next day they were in my hand, boy that red paint is high! No red paint, the most expensive one cost me $28.00. If you have a great store around it can be done, just don't try and pop into auto zone and ask the zit faced kid behind the counter for it. Hope this helps you
Rabbitchoker
07-11-2005 14:38:49
I meant to say the tie rod ends on the steering drag rods for a 300 utility. Thanks
PAULIH300
07-11-2005 14:44:06
 Re: 300 Utility PARTS?????? in reply to Rabbitchoker, 07-11-2005 14:38:49
I dont believe anyone reproduces them.MOOG doesnt offer any ends that come close.Thankfully,I bought used assemblies in good shape instead.
