PTO Belt Pulley Packing F-20
mshadow
07-11-2005 17:42:28
I have a 1939 F-20. I am in the process of restoring it. When I changed the oil in the transmission, the oil was so thick it almost came out in clumps. Since changing it, I now have oil leaks around the pto shaft and the belt pulley shaft. Will changing the packing around the pto shaft and the belt pulley stop these leaks? If it does, how hard is it to change the packing? Thanks!
Shadow
F-Dean
07-11-2005 19:30:54
 Re: PTO Belt Pulley Packing F-20 in reply to mshadow, 07-11-2005 17:42:28
Rice Equipment (814) 226-9200 has new packing.
Nebraska Cowman
07-11-2005 17:49:07
If it not too hard you can tighten the packing. Otherwise just dig out the old and replace with new rope packing. not hard at all. i think you want the 1/4 inch size
