Farmall A Gas Tank Leak
Duane H
07-12-2005 07:39:39
I have a very slight leak on the bottom of my A gas tank. I can just see a little moisture on the bottom of the tank but no drips. Is it better to try to us JB weld from the outside or a gas tank liner from the inside? I have used Red Kote liner before but the A has a baffle in the tank and I am not sure how well it will work with the baffle. What do you guys think? Thanks for the help.
chip man
07-12-2005 12:45:17
 Re: Farmall A Gas Tank Leak in reply to Duane H, 07-12-2005 07:39:39
I lined the tank of my "A" with Kreem, it worked even with the baffle. Dad had repaired it twice with JB weld, and it doesn't last, because of the rust on the inside.
Dave from Texas
07-12-2005 07:53:15
JB weld would be a quick fix. I would think that there are several spots on the tank that are thin. Linning would probably be better in the long run.
