350 Rear Axle Seal
Illinois Boy
07-12-2005 09:22:06
Just developed an oil leak around the right rear axle on my 350 standard (gas). I checked my manuals and haven"t found anything that tells how much of a "task" this would be to fix. It looks like I can remove a couple of bolts and a plate to get to the culprit - anyone have any experience with this? Would I have to take off the rear tire to make this happen?
Thanks in advance
Roger WI
07-12-2005 19:16:58
 Re: 350 Rear Axle Seal in reply to Illinois Boy, 07-12-2005 09:22:06
I assume that a 350 is the same as an H or M to change the seal. All you need to do is jack up the tractor just high enough for the wheel to clear the ground. Park the tractor next to a post on level ground or inside a garage so the wheel can be leaned up against it without tipping over as the wheel and tire are heavy (especially if you have fluid in the tires). Once you have the wheel off the seal is easy to change. Roger
El Toro
07-12-2005 13:12:40
I think you would have to pull the wheel if the axle goes through the seal. Hal
Illinois Boy
07-12-2005 14:42:50
 Re: 350 Rear Axle Seal in reply to El Toro, 07-12-2005 13:12:40
Thanks for the information - I was afraid of that...
