Main Rod Caps?
iester
07-12-2005 18:08:52
I have them in right order.Not sure if they are turned right,Any way to tell? Thanks in advance.Lester
El Toro
07-12-2005 18:22:04
 Re: Main Rod Caps? in reply to iester, 07-12-2005 18:08:52
I think the numbers on the main caps should face toward the camshaft and the rods and caps too. What tractor is this? Hal
iester
07-12-2005 19:05:26
 Re: Main Rod Caps? in reply to El Toro, 07-12-2005 18:22:04
Thanks that is why I posted, Seems one is turned around.The numbers aren't faceing the same way,I just want to be sure before I reinstall Help!!
iester
07-12-2005 18:26:40
You guy's type to fast for me.It's a 350 utility
Allan in NE
07-12-2005 18:14:35
Hi Lester,
The locking (anti-spin) tabs always go on the same side as the tab on the parent base.
Allan
iester
07-12-2005 18:24:06
 Re: Main Rod Caps? in reply to Allan in NE, 07-12-2005 18:14:35
So the tab's line up with each other..Right? Thanks Allan
