voltage regulator location on a MD
Jesse
07-13-2005 12:48:36
Where is this regulator supposed to be? I can't readily tell. I didn't take it off. It doesn't seem to go on the generator or the light post. Are there any other locations where this might go? (The tractor is an MD.)
DWV
07-14-2005 12:59:32
 Re: voltage regulator location on a MD in reply to Jesse, 07-13-2005 12:48:36
Later MDs mounted on rear gas tank support also.
KevinDM
07-14-2005 08:12:50
Mine mounts on the right side of the steering column just below the switch box. SMD.
n9lhm
07-14-2005 07:14:33
Mine"s on the left side of the radiator near the top. That"s also where the instruction manual shows it. Brian
Geoff NY
07-13-2005 16:30:02
Mine was on the radiator up under the hood, above the generator.
