rocker arm/tappet shaft question
upred
07-13-2005 18:51:13
I have an M international and the shaft that holds the rocker arms in place, has the two end rockers rusted, possibly due to lack of oil. What should I do, repair shaft or try to find a good used one?? any one have one they don't want?? please help thanks - Rick
steve k corum
07-13-2005 19:19:23
 Re: rocker arm/tappet shaft question in reply to upred, 07-13-2005 18:51:13
you need to run it with the cover off. see if it oils good and the pushrods turn by finger, if not take the rocker arm assembly off and clean the oil passagesfor rust. hope this helps. stev corum
upred
07-13-2005 20:13:27
 Re: rocker arm/tappet shaft question in reply to steve k corum, 07-13-2005 19:19:23
thanks I'll give that a try first
