Order Farmall Cub Parts Online
Cub Trasmission help!
GNB
07-13-2005 19:02:08
I see the problem with my 49 cub raising cain in 1st gear. Looked in the top cover and there is a tooth broke off of 1st gear. How hard is this gear to get out? I have never done any trasmission work but I do have the manual and some of it is not clear. Thanks in advance.
GNB
Jim Becker
07-13-2005 19:14:07
 Re: Cub Trasmission help! in reply to GNB, 07-13-2005 19:02:08
If it is the upper gear, you have to split the tractor in front of the transmission. Then you can remove the upper shaft from the front, freeing the gear.
If it is the lower gear, you have to take the whole thing apart. The lower shaft comes out the back, which requires pulling out the differential assembly.
