super a positive or negative ground
Paul H
07-13-2005 20:15:58
I disconnected the battery cables to change the battery and didn't pay attention to which terminal was grounded. Does it matter? If so how can I tell which is right?
thanks
Paul
gene b
07-14-2005 02:47:17
 Re: super a positive or negative ground in reply to Paul H, 07-13-2005 20:15:58
It should be positive ground unless someone has messed with the system. The SA will start just great with the 6v system. Seems there isnt a day goes by without someone having a problem with changing to 12v when all they had to do was get the system they had working.
R-cubed
07-13-2005 20:23:07
I believe all the old letter series tractors were positive ground unless someone messed with them. Connecting it backwards is bad news. The positive post however is a little larger than the neg so you probably can tell by the cable fit if it is right. I suggest changing it to 12V negative ground and put an alternator on it like we all do on these 6V clunkers.
Vern
07-13-2005 21:08:42
 Re: super a positive or negative ground in reply to R-cubed, 07-13-2005 20:23:07
R-cubed;
Not all of us change out 6V tractors to 12V. Just the ones that don't know how to make the 6V work.
Vern
Red Dave
07-14-2005 05:07:15
 Re: super a positive or negative ground in reply to Vern, 07-13-2005 21:08:42
You're right Vern.
I don't have any trouble at all with a 6 volt system on these A's & B's.
Hugh MacKay
07-14-2005 02:18:27
Vern: Good point, and you know half those guys that change to 12 volt don't get along any better than they did with 6 volt. Perhaps the biggest thing they did wrong with the 6 volt system, was go to auto parts store and buy a replacment battery cable too small for the job.
Most folks don't look at it this way but as far as I'm concerned there are two issues here 6 or 12 volt and either can work well. The second is charging, generator or alternator and that can be either 6 or 12 volt and again either can work well. The alternator will give better charging and is less expensive to repair.
